Fluids?
Old Aug 17, 2004 | 03:50 PM
ACDenali's Avatar
Default Fluids?
On the same note as O3GMC's post about fluids, but I didn't want to hi-jack his thread.....
My truck has 51k miles on it, I have not changed the rear end, transfer case or transmission fluids.
Is it time to change these? Also, what brand do you guys run in your trucks?
Any tips/tricks when doing the fluid swaps also ...
Thanks alot.
Old Aug 17, 2004 | 05:09 PM
Mn Avalanche's Avatar
As far as recomendations go.Tranny is recomended at 50k in manual,also auto trak t cases are recomended at 50 k also.Make sure yu use gm autotrak fluid you will need 2qt's at 7 dollars a qtThe rear and front diff, are check and fill as needed.I only have 20 k on mine and have changed rear diff 2 times allrdy.If yu have the g80 unit i would change it just use any good full syn 75-90gl5 and yu will be good to go. Front diff fluid is normal 80-90 gl5,its your call if yu want to switch it to synthetic or not.
Blwn99x
Mar 24, 2023 11:14 AM
drummer0415
11
Oct 24, 2015 08:16 PM
turbo6c3
Oct 5, 2015 06:11 PM
fortune46x
Sep 16, 2015 08:18 AM
Noah Burns
Sep 13, 2015 09:28 AM
