fluctuating oil pressure question
Old Mar 2, 2015 | 11:44 AM
Chiphead's Avatar
On high volume pumps, some excess oil has to go through the pump relief valve to keep oil pressure in check. sometimes this causes the pressure to bounce around a bit as the relief does its thing.
I wouldn't worry about a 5psi variance, it's probably gauge response..
Old Mar 12, 2015 | 09:57 PM
GREENSIERRA's Avatar
just a little update, I got my motor torn down to do the 408 and pretty sure I found why I had fluctuating oil pressure.
I had a main bearing that decided it wanted to mate with the crank
Old Mar 13, 2015 | 05:40 PM
01silvy's Avatar
Yeah that will certainly cause a oil pressure issue. At least you figured it out!
Old Mar 15, 2015 | 05:03 AM
SlowDude's Avatar
Good to know.. Ive been watching mine do the same thing but only started after swapping to Penzoil ultra platinum 5w30 after I was convinced the motor was good and broke in. Nothing in my filter thus far though. Been thinking maybe the stepper motor in the gauge. Maybe I just need to run a mech gauge. Hey GREENSIERRA, How is that cam working out for ya? I dont have a lifted truck or big tires since Im not a 4x4 but I do know there has to be more this baby could do. My compression is similar to yours and planning to do a 14FF with maybe a 4.33 in the very near future. So looking for a different cam and swap out the intake and TB then throw a bunch of nitrous at it.
Old Mar 15, 2015 | 08:45 PM
I am glad I pulled the motor apart or it would have self distructed.
lol
I cant tell you how the cam is cause I just got my motor back from the machine shop Friday night, I did a frame off on the truck and have most of it back together now but just waiting for head gaskets before I can fire it up.
ends up my compression is actually 12.1:1
superchomper2003
Aug 26, 2015 09:39 AM
05GMC4.8
Aug 7, 2015 09:55 PM
USMCvet0311
Aug 1, 2015 07:45 AM
Ferocity02
Jul 17, 2015 07:05 PM
