Stage1, stage2, stroker
Registered User
Goodday all,
who can me explain stage 1, stage 2 mods?
To refer the term Stroker, all engine can become stroker with just a stroker kit?
383 Stroker Kit | eBay
What is the advantage with a stroker?
If i buy a lq9 for my avy, i can transform this stock engine in a stroker?
I've seen also bare block 408 stroker
TSP 408 C.I.D. LQ9 Short-Block
Great pricing difference, can be explainable with the quality?
I'm lost like Frodon in Mordor Plains
Thank you Guy's
Thank you Guy's
11 Second Club
There is no real definition of stage 1 and stage 2 other than stage 2 should perform better. It's just a marketing thing.
I can't look at the link you provide because I'm behind a firewall, but those cheap e-bay kits are usually just that... cheap. Beware of inferior parts.
When you stroke an engine, basically you're putting in a longer stroke crankshaft (and pistons with the correct wrist pin height to match). The advantage is more displacement and more horsepower/torque. Larger engines have more potential for performance.
making an engine a stroker simply means that the pistons will travel further down into the block of the engine. You inscrease the stroke of the piston and therefore the displacement. For example a stroker turns a 6.0 into a 6.6 (364ci into a 402ci, or 408ci if you bore it as well). Increasing the stroke of an engine generally makes it more torquey.
The stage x kits are kind of silly... i dont see many GM performance packages like that because people who modify generally know more about it and pick parts that are tailored specifically to them. I find thats more common terminology with fords, and most euro/jap tuner companies.
Registered User
Great, is most clearer now
But i think my major problem i'can't choose my way, i'know it exist more and more combination.
The 2 thing i'm sure are hp gain and conserve a dayli driver truck.
Lq9 with ported heads, headers, cam etc or an lq9 stroker kit...
I bought some books, how to build gm ls series. but i never read how to know if kinds of parts fits with others, ex: head from ls1 fits with a 408 etc..
You impress me, how you know all?
you are born to make HP lol
Thank you so much
Thank you so much
BROKE-aSS-BLAZER
10-13-2017 03:50 PM
