FLP tranny durability
Old Feb 24, 2005 | 12:15 PM
  #21
zippy's Avatar
that wasn't the question and it wasn't directed to you.
Old Feb 24, 2005 | 12:19 PM
  #22
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Zippy, my FLP only shifts really hard at high throttle (and then my fillings come right on out). During normal cruise, it shifts pretty smoothly.
Old Feb 24, 2005 | 01:13 PM
  #23
BigKID's Avatar
Originally Posted by 12sec.5.3
I have a friend who is a GM certified transmission mechanic who could build my 60 to a 65 with new clutch packs, five pinion planetaries and a couple of other different parts. I just don't know if this would be as reliable as the flp?
The trans guy at one of the local dealerships here builds up trannys on the side and has built several for some of my f-body friends(one of them is in the high 10's others are in the 11's) and they are holding up great. I will be having him rebuild mine will all hardened parts, 5 pinion planets and better clutches when the time comes. If it wsnt for his rep and the money I will be saving with him, I would be going the FLP route.
Old Feb 24, 2005 | 01:21 PM
  #24
zippy's Avatar
that must be part of the vacuum controled pcs system. that would certainly make things much more comfortable for most drivers.
with as much stall as 2bseen is running it would seem that everything would feel soft. how was the 65E working when you pulled it out? (2bseen).
Old Feb 24, 2005 | 07:51 PM
  #25
CHarris's Avatar
Was it Zippy or pissy....damn.
Old Feb 24, 2005 | 08:34 PM
  #26
parish8's Avatar
single digit dreamer
from talking to chuck at flp i get the idea he spends a lot of time checking all the little details and clearances. i am not saying he is the only one that can build a tranny but i think there is more to it than just useing the right parts.
chuck also has some first hand experience working with the special needs of higher hp 5000lb trucks. the extra weight we have requires some different settings and parts than the cars.
Old Feb 24, 2005 | 09:13 PM
  #27
hellbents10's Avatar
LS1Tech Sponsor
Agreed there are people who are trans. assemblers and then there is trans builders. I like the 60/65 and have seen it live through quite a bit.
Old Feb 24, 2005 | 10:23 PM
  #28
zippy's Avatar
you can use either. when i want your opinion i'll give it to you.
Old Feb 24, 2005 | 10:40 PM
  #29
ChevyCoonass's Avatar
I have been having my FLP Level 5 for 3 months and driving it hard and it feels and is doing great! I am pushing 615hp. Holding up good so far.
Old Feb 24, 2005 | 10:49 PM
  #30
Kano's Avatar
dont knock the 80 too hard
02denali ran some impressive na 5.3 times with his 80
compared to his 60
but when mine goes
its level 5 time just for the simplicity
and good reputation
On the shift firmness thing I think theres a point its too hard
and you break things and a point its too soft and you burn things
the 1 thing I dont understand is the flp level 5 has 2 washers
better bands ,clutches etc
my stock transmission with 0 washers shifts plenty hard
seems like the level 5 would break windshields
with all that
or is there a reason behind this?
