Flow matching injectors?
Old Oct 13, 2010 | 02:39 PM
02'Z71ONDUBZ''s Avatar
Default Flow matching injectors?
I've got a new set of 44lb injectors but am considering selling them and picking up a set of 60lb injectors instead. My question is, what should be done to a set of used injectors to ensure that they are flowing correctly/ ready to install? Should they be sent off and cleaned, or is that something I could do myself? Should they be flow matched, or is that necessary? I'm just worried about picking up a used set and then having fueling/tuning issues from them. Any recommendations are appreciated
Old Oct 13, 2010 | 07:59 PM
MikeGyver's Avatar
Send them off and get them cleaned. They will tell you if they are mismatched. Flow matching is accomplished by buying a new injector to replace the oddball, and then you put the oddball into a garbage can.
I had one injector that flow a lot more, it makes for fun idle tuning.
Three6GMC
Oct 27, 2015 08:04 PM
chvy=power
Sep 8, 2015 11:06 AM
lxcoupe
Sep 2, 2015 12:58 AM
05GMC4.8
Aug 7, 2015 09:55 PM
jrplz
Jul 9, 2015 12:07 AM
