floor shifter...
Old Aug 6, 2002 | 01:23 PM
hihosilver's Avatar
Default floor shifter...
i'm thinking of putting a hurst or b%m floor shifter in my truck, it's a 4l60e automatic...just wondering if it's possible to do this with all the electronics? <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" /> column shifter
Old Aug 6, 2002 | 02:07 PM
Ryan23silverado's Avatar
Default Re: floor shifter...
Sure it's possible, but don't you already have this done to your truck? <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Old Aug 6, 2002 | 02:26 PM
GREGGO's Avatar
364LS1truck
Member # 5430
posted July 15, 2002 01:31 PM
installed the cam and heads, the electric fans were a bitch, but only cuz i was drunk by then i think. the forged pistons and crank were a great addition, especially now that i've installed the nitrous kit. i put in a floor shifter for the automatic last night, it looks kick ***. later y'all
Contact this guy, he really knows his stuff. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
<small>[ August 06, 2002, 02:28 PM: Message edited by: Fast4.8 ]</small>
Old Aug 6, 2002 | 02:54 PM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
If 364LS1truck can't help you out <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> , take a look here:
http://www.blown4x4.com/B_M_Shifter/b_m_shifter.html
Old Aug 6, 2002 | 03:48 PM
RED2K's Avatar
YOU shouldnt need it cause you beat a stroked out SS... <img border="0" alt="[bullshit]" title="" src="graemlins/gr_bs.gif" />
Old Aug 6, 2002 | 03:50 PM
RED2K's Avatar
you might have trouble making room with the jet engine and all <img border="0" alt="[devil]" title="" src="graemlins/gr_devil.gif" />
Old Aug 6, 2002 | 04:32 PM
XLR8NSS's Avatar
Adkoonerstrator
Good info Neil
I wonder if you leave the stock cable hooked up like he did if you can take the stock shifter on the column off.
Then you could get the steering column cover from a manual truck to clean things up.
I guess the nuetral/park switch, brake interlock, and reverse lights would still work with it hooked up like that. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> That would really simplify the install.
John
Old Aug 6, 2002 | 06:08 PM
IslandTahoe's Avatar
When he says he " was able to retain the factory shift cable and the benefit of this is that the reverse light and safety measures from the factory still work perfectly! The red arrow indicates were the B&M cable attaches on the back side." it sounds like the used the B&M cable directly to that location from the floor shifter, but where is that factory cable running to/from?
Does the stock shifter arm unscrew from the column?
Old Aug 6, 2002 | 08:51 PM
Blown 4x4's Avatar
islandtahoe - That's my Yukon that I did the shifter on. I retained all factory safe guards and displays. Pretty simple but keep in mind it's been a few years now and my memory is a little fuzzy.
Let me know what specifics you want and I'll try and answere them.
The stock shifter is held in by a pin, just drive it out with a punch. You will also need to remove the detent arm so that the mechanism rotates without interference. I retained the key removal safety mechanism so you cant remove the key while in gear. I just relocated the internal small cable to the other side of the column and I have to pull it to remove the key. Real simple and it works good.
Lee
Old Aug 6, 2002 | 10:38 PM
hihosilver's Avatar
blown, does the display on the dash still work? our new trucks have tow/haul mode, how would i make that work in your opinion on the new shifter? i definatly want to do this to my truck...it'll probably go in this weekend.
drummer0415
11
Oct 24, 2015 08:16 PM
Closer_2001
Sep 24, 2015 09:15 PM
GM1697
Sep 22, 2015 09:54 PM
69z-28
Sep 21, 2015 07:31 AM
