Flexible Fuel Engine
Old Sep 20, 2005 | 10:17 AM
mzr3yt's Avatar
Default Flexible Fuel Engine
The owner's manual in my '05 Silverado (5.3 liter) states that the engine can run on ethanol. What parts are different from a normal 5.3 liter? How does the computer know to adjust for ethanol?
Old Sep 20, 2005 | 12:36 PM
kbracing96's Avatar
The fuel system is larger, and has larger injectors. There is a sensor then can tell how much ethanol there is in the fuel and adjust the injectors accordingly. You will get less MPG with ethanol, cuz it has a lower stoich rate, but it is usually cheaper, so you have to do the math and see if its worth running. You may also get a little more performance out of it since it is a higher octane fuel.
Old Sep 20, 2005 | 02:26 PM
1SlowHoe's Avatar
Destroyer of Transmissions
What he said.
P.S. Be sure to tell Magnacharger that when you order your Radix.
5.3Okasai
Mar 9, 2022 01:07 PM
Noah Burns
Sep 7, 2015 05:50 PM
lxcoupe
Jul 21, 2015 02:12 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
jrplz
Jul 9, 2015 12:07 AM
