Flex-A-Lite Fans Wireing
Old Mar 27, 2004 | 08:00 PM
Silverado03's Avatar
Question Flex-A-Lite Fans Wireing
hey everyone*********HELP***********
Which wire is for the ignition for the Flex-A-Lite Fans
The Fans will not turn on no matter what temperature the truck is.
I hooked up the terminal # 9 to the battery and the fans work fine but I need to fine the ignition wire??
Which wire is it ??????
*****ANYONE*****
File Type: bmp
Old Mar 27, 2004 | 08:42 PM
one03sierra's Avatar
Formerly one92rs
Talking
are you wanting to know where to hook it up in the truck right? i hooked mine to a terminal in the fuse block under the hood. i hooked mine to the relay terminal. if you are standing on the drivers side and remove the cover. on the right hand side of the box there are 4 holes where a relay could go. the right side closest terminal is ignition. good luck.
Old Mar 27, 2004 | 08:52 PM
I have a photo that I just added right now
Old Mar 27, 2004 | 08:54 PM
agreif's Avatar
Step 15.
http://james.jaguar.net/agreif/fans/fanstech.htm
02 - can you take a pic of where you hooked it, sounds like it might be simpler.
Old Mar 27, 2004 | 09:01 PM
Originally Posted by agreif
Step 15.
YES!!
Old Mar 27, 2004 | 09:12 PM
Formerly one92rs
Talking
yay here you go.
i left a little extra wire.
Old Mar 27, 2004 | 09:23 PM
Here's other photo. I think I have other fuse box then your.
Here a better photo
Old Mar 27, 2004 | 09:32 PM
Formerly one92rs
Talking
yes you do. start checking them empty fuse holes for an ignition source.
Old Mar 27, 2004 | 10:01 PM
Formerly one92rs
Talking
well if you find out let me know.
Old Mar 27, 2004 | 10:03 PM
THANKS!!!!
