Flex-A-Lite Fans Wireing
Old Mar 27, 2004 | 10:33 PM
one03sierra's Avatar
Formerly one92rs
Talking
I usually tap the green wire with the white stripe. This goes to the connector that plugs into the very back of the compressor (can be seen laying under the truck on the passenger's side). If your trying to find the keyed power wire take off the fise box cover then lift up the part that has the fuses so you can see the wires under it. Your going to see 6 "blocks" of fuses. Look to the far right column of the center block and count down 9. There should be a pink wire there. That's the wire you want!
Tom
i got this off the silverado ss sight
Old Mar 27, 2004 | 10:44 PM
Silverado03's Avatar
Tom
Thanks Tom I'm going to try it on Sunday. I'll let you now which one I used.
Old Mar 28, 2004 | 12:17 AM
Flyer's Avatar
I would pull the fuse block up, there is a clip next to the fender you can pull out, and the fuse block pivots up. Find a wire under there. Lots to choose from. I think I used a pink one in the middle section. Mine was divided into 3 sections front to back.
Old Mar 28, 2004 | 04:18 PM
Thumbs up All Done!!!
Thanks everyone with helping me. I got under the fuse box and found three pink wire's that were 3 into one. I taped one of those and works good...Thanks to all
Porscharu914
14
Jan 20, 2016 10:45 AM
lxcoupe
Sep 23, 2015 12:11 AM
kalikid06
Sep 20, 2015 07:46 PM
97gmc
22
Sep 8, 2015 10:56 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
