flex a lite fan kit??????'s
Old Jan 20, 2007 | 11:58 AM
BlkNight02's Avatar
Default flex a lite fan kit??????'s
Is the flex a lite fans worth the money and time or should i go to saving a little more for the o5 or ls1 oe fans and get a harness made? and do i need to have it tuned afterwards?
Old Jan 20, 2007 | 12:06 PM
truckmann's Avatar
I don't think the FAL's are worth the money. Most people say the controllers are junk anyway. Cheapest way is to get some LS1 fans and a harness. The 05 fans only fit a 34" radiator so if you don't already have a 34" you will need to get one. In order the run the fans with you pcm you will need a tune, but you can but an external controler to run the ls1 fans or put them on a manually opperated switch.
GXPJAY
Feb 13, 2022 08:15 AM
thunder550
Oct 8, 2015 04:53 PM
05GMC4.8
Aug 7, 2015 09:55 PM
