fixing collector exhaust leak
Wearin' da big hat
I got flanges welded onto my pacesetters awhile ago, and they used shitty gaskets that leaked, so i took em out and put in the thicker alluminum ones. Now I cant get them to seal right and they leak bad. BlackGMC suggested knife edging them and some other stuff. I still dont get exactly what I need to do to them, but is there anything I can put on them to help it seal, like some high heat RTV or anything like that? How can I make these leaks going away, its killing me when I have my cutout closed.
actually the collector gaskets at autozones seem to hold up fairly well. Had one of them in my old truck on the cutout...never leaked and I took it on and off frequently. (If it is the same style gasket)
More than likely it is your flanges and not what gasket your using... From the 3-bolt flanges I have seen they warp and leak.... They warp because the flanges themselves are rather thin and bend easily... On the exhaust I am building now I got two flanges and welded them together to make them twice as thick to prevent warping... Another solution is to get the composite ones and put a pretty thick bead of the High Temp RTV on them....
Wearin' da big hat
I've really been thinking about getting you to do any exhaust for me.
If you're interested, shoot me a PM.
My leaks are killing me since i got the LTs and ORY. i am running so rich since the install that the truck misfires quite frequently (not sure if its in the tune or because my O2s are seeing a little fresh air). i just put on some nice staggered band clamps yesturday to no avail. now i am gonna try the sealing tape from VIP and clamp over it. hopefully this helps.
