first oil change?
Old Aug 26, 2004 | 09:43 PM
JoeJ's Avatar
Default first oil change?
well, i've had my '05 for less than a week, but I'm already thinking about the first oil change. I'll probably change it after I hit 500. What oil do you guys run in your trucks? how many quarts? My truck is an '05 5.3. TIA
Old Aug 26, 2004 | 09:50 PM
hink9's Avatar
doesnt brand new engine oil have solvents and soaps and such that help the break in period, i always thought it was a good idea to run your new oil till your normally scheduled maintenace, i use mobil 1 synthetic, right now its really hot so i use 10w-30, in winter i use 5w-30. like it even matters, they hold 6qt's.
Old Aug 26, 2004 | 10:27 PM
Mort's Avatar
I use Amsoil 10W30 ATM in the summer and Amsoil 5W30 ATM in the winter. I use a Baldwin B1432 filter which is the equivalent to the AC Delco PF59. I use the GM Oil monitoring system on my truck and it was 10000 miles since the last change. I did my first change at 3000 miles and used dino GM 10W30 and a PF44 filter supplied free by the dealer. The engine takes 6 quarts unless they changed the capacity since '03.
Old Aug 26, 2004 | 10:37 PM
shandy294's Avatar
I changed mine at 3,084 miles the first time and run Mobil One 5w-30 but don't know if there's a 'right' or 'optimal' time. I don't believe in waiting for the truck to tell me when to change it,though. I check it at least once a week and don't like for it to pass a certain shade of brown...un-scientific but to each his own I guess. I usually use Wix filters.
Old Aug 27, 2004 | 01:05 AM
Mangled03gmc's Avatar
Baltimore Whore
not to hack one the post but i did not know that they held 6 quarts of oil. what about the 4.8 6 also. i have only been puttin 5 in. sry
Old Aug 27, 2004 | 01:35 AM
Tokez420's Avatar
i have a 02 4.8L and it takes 6
Old Aug 27, 2004 | 08:13 AM
I changed my filter at 500 and 1000
Then full LOF at 3k and switched to M1
Mine hold 6 1/4 qts with a PF 59
Old Aug 27, 2004 | 08:38 AM
zippy's Avatar
i'd recomend a new pf 46 with some standard 10w30 oil. make sure to reset the oil life moniter. after the change oil lite comes on after that, i'd use mobil 1 10w30 in the summer and 5w30 in the winter with a pf46.
Old Aug 27, 2004 | 10:44 AM
STOCK_SUCKS's Avatar
Pf46 Has The Anti Drainback Valve
Old Aug 27, 2004 | 11:00 AM
59 does as well - longer style filter
