Finished intake setup, now trans is slipping.
Old Sep 24, 2003 | 10:45 PM
Black Blown 02's Avatar
Default Finished intake setup, now trans is slipping.
Just finished a 4" from MAF to TB intake setup on the truck. Did this to cure boost leak and popping the stock intake.
One problem--now my part throttle 1-2 and 2-3 shifts are slipping. slipping so bad I have to let off to get it to catch the next gear. They used to be super hard and quick.
I tried some 3/4 throttle, and they still barked the tires, so I dont think its my trans going out.
The only thing I did that I can think of that might cause it is, while pressure testing my intake tubing I found 1 leak--3 holes around the outside of the MAF. Dont know what they are for. Looking back this probably wasn't a good idea, but I dabbed some silicone into the holes to seal them up.
Ive heard MAF calibration can change line pressure. Could this have done it?
Old Sep 25, 2003 | 06:00 PM
Default Re: Finished intake setup, now trans is slipping.
well, going out to dig the silicone out now.
Old Sep 25, 2003 | 06:46 PM
ShortCrew's Avatar
Yep. The MAF has a lot to do with the line pressure.
Old Sep 26, 2003 | 01:01 AM
454SuperSport's Avatar
you think a vaccum modulated upgrade would fix this? i know they use them on the flp trannys. www.pro-built.net sells the kit to do this and it comes with a box to plug into the harness to keep the computer happy. just a thought
Old Sep 26, 2003 | 01:58 PM
Procharged LM7's Avatar
You have any pictures of your intake setup?
BTW mine slips at WOT from 1-2. I think the band is slipping. Does not do it unless WOT
ferrellrooster
Mar 6, 2025 03:22 PM
The_W
Oct 28, 2015 09:00 PM
KyleW707
Jul 29, 2015 08:17 AM
Aboss
Jul 9, 2015 10:28 AM
08DenaliT
Jul 8, 2015 09:13 PM
