Finished the Fast 90/90
Old Mar 2, 2008 | 06:29 PM
built408's Avatar
Default Finished the Fast 90/90
Well I finally finished the fast 90/90 setup... Just had to show it off some.. Getting tuned this week, can't wait for the results...
Old Mar 2, 2008 | 06:35 PM
Mort's Avatar
That sure looks nice. Good luck on the numbers.
Old Mar 2, 2008 | 06:41 PM
ZR1 DREAMING's Avatar
Are you running an electric water pump? Do you have any head on shots of the accessory drive, WP, and TB position?
Looks good man.
Old Mar 2, 2008 | 06:49 PM
built408's Avatar
Yes I'm running an electric water pump... I dont have any pics right now but I can take some. I came up with my own way to relocate the idler puller. I just used a c6 corvette idler pulley (alittle smaller) spaced out and mounted to the existing mounting bolt right under the alternator... Had to order a 6inch long 10mm bolt to mount it tho. And used a longer belt. Worked out pretty good...
Old Mar 2, 2008 | 07:56 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
Looks great can't wait to see some #s
Old Mar 3, 2008 | 10:53 AM
built408's Avatar
Thanks
Old Mar 3, 2008 | 11:05 AM
TXsilverado's Avatar
hey, can you post a picture of the pully method you used? how much did everything cost in the end?
Old Mar 3, 2008 | 11:25 AM
dkota1968's Avatar
That looks bad *** man, good job. id also be interested in those pics.
Old Mar 3, 2008 | 11:26 AM
Llaverito's Avatar
Something like this except this is the same truck pulley
Old Mar 3, 2008 | 12:39 PM
KISS method FTW!
that looks alot easier and cheaper than the relocation kit. what grade bolt is that?
