Findings after pulling head, re: broken valvespring
Old 03-15-2013, 11:33 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Originally Posted by GMCtrk
Tooley platinum springs with Ti retainers ordered
ARP head studs and assembly lube ordered
I heard Summit price matches gmpartsdirect on LS9 head gaskets so I'll be ordering those tomorrow.
Did you already do the Trunnion upgrade???
Old 03-15-2013, 11:34 PM
GMCtrk's Avatar
No, rockers are totally stock, and are in good condition.
Old 03-15-2013, 11:43 PM
1FastBrick's Avatar
With all this work your doing, you might want to consider it. You only need 1 cover to pop off and spill the bearings...
Old 03-15-2013, 11:45 PM
MechE's Avatar
where'd you get the studs from if you don't mind?
Old 03-16-2013, 12:00 AM
GMCtrk's Avatar
ebay.
Old 03-16-2013, 11:15 AM
Time to go to the beer store and get some lottery tickets!!! Glad to see you didnt ruin anything.
Old 03-19-2013, 09:20 AM
Vortec350ss's Avatar
Wow thats awesome! you really lucked out!
Which direction are you going to go with the cam?
Old 03-19-2013, 09:29 AM
GMCtrk's Avatar
I decided just to stay with the current cam. I may change it out in the future depending on how things workout.
Heads are off to the machine shop later this morning for inspection, cleaning and spring install.
Old 03-19-2013, 09:40 AM
Gadgetized's Avatar
So that never even bent that valve?
I would do the trunion upgrade on anything that isn't going to be driven in stock form. You are putting more pressure on it by using stronger springs, more than likely a different cam, and more than likely higher RPM's. If one gives out it doesnt just break, it spreads needles bearings throughout your engine. The upgrade is $130 and a little bit of work for cheap insurance.
Old 03-19-2013, 09:49 AM
How much is it gonna cost for all of that work to the heads?
Quick Reply: Findings after pulling head, re: broken valvespring
