Finally some facts..
Old Jul 20, 2005 | 07:57 PM
Masked's Avatar
Banned
Default L33 Vs. LM7
Originally Posted by closet red neck
What is the L33 engine??? Specs, please....I heard a bunch of guys talking about it on here and always wanted to ask.
L33 H.O. 310 HP 5.3 =
Aluminum deep skirt 6 bolt main block.
LS6 heads cast number 799.
Flat top pistons w\teflon coated skirts & floating wrist pins.
RPO RPO
LM7 L33
VIN VIN
T B
Compression Ratio Compression Ratio
9.49:1 9.9:1
Camshaft Lobe Lift - Exhaust Camshaft Lobe Lift - Exhaust
6.96 mm 7.2 mm
0.274 in 0.283 in
Camshaft Lobe Lift - Intake Camshaft Lobe Lift - Intake
6.82 mm 7.2 mm
0.268 in 0.283 in
Valves - Valve Lift - Intake Valves - Valve Lift - Intake
11.58 mm 12.24 mm
0.456 in 0.482 in
Valves - Valve Lift - Exhaust Valves - Valve Lift - Exhaust
11.82 mm 12.24 mm
0.465 in 0.482 in
Old Jul 24, 2005 | 03:46 PM
SEMOscrew's Avatar
i thought L33 was only in the excab???? what was the vin code to tell if you had one?
Old Jul 24, 2005 | 04:13 PM
BlownChevy's Avatar
blownerator
25 Year Member
"B" in the 8th position.
Old Jul 24, 2005 | 04:14 PM
Masked's Avatar
Banned
Default L33 is "B" in the VIN.
The eighth number in the VIN is a "B" for the L33 and a "T" for the LM7.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
dsbodley
Nov 14, 2015 09:46 PM
cheyenne383
Nov 13, 2015 09:24 AM
Velocity1
Oct 2, 2015 08:01 AM
Lthompson
Oct 2, 2015 12:45 AM
