Finally figured out why my engine is running hot at idle
Old Jul 25, 2007 | 07:55 PM
12 Second Club
Default Finally figured out why my engine is running hot at idle
I don't know if anyone knows but when you have an under drive pulley the water pump slows down and when it is like 90 to 100 degrees out at idle with the ac on it causes the engine to run hot. What do you guys think. Thanks, Jared
Old Jul 25, 2007 | 07:57 PM
nightrunner's Avatar
Mr. Obvious
how hot?
Old Jul 25, 2007 | 08:05 PM
12 Second Club
Old Jul 25, 2007 | 08:06 PM
12 Second Club
before the pulley it used to stay at 190-195
Old Jul 25, 2007 | 08:07 PM
Mr. Obvious
20 degrees isnt going to hurt it
if it would make you feel better you could get
160 thermostat
electric water pump
electric fans
Old Jul 25, 2007 | 08:16 PM
12 Second Club
I have electric fans. I am a ford mechanic and a safe temperature for a ford is 220-230 so I would think gm is the same and 210-215 should be fine.
Old Jul 25, 2007 | 08:30 PM
dewmanshu's Avatar
Moderately Differentiated
The only danger to those temps is if you have done tuning to your truck and removed all spark retarding safe gaurds. Hence the benfit of running cooler...more spark.
ullose272
Aug 5, 2016 02:05 PM
chopperloco
Jul 10, 2016 10:45 PM
stealthperf
34
Feb 14, 2016 11:35 AM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
