few quick questions
few quick questions
had a few quick questions for some of ya.
my first is that i was just curious if i need to do somethin with my fan shroud since i did my efans? i havnt overheated even with the fans off, either way with them off or on my temp stays right about at 200...is this normal? with your efan setups with the fans go on does your temp drop or stay where it should? also what have yall done with your shroud's leave them off or modify them or stock? ive got two single 12's there 80w 12 volt fans, i have no clue what brand they are though, i can honestly say they push a good amount of air
my 2nd question is about my tranny temp guage,should there be a harness where my trans temp in the original cluster (mine doesnt have it) or do i have to wire it up some other way and drill a hole in my trans pan??
my last question is for my wideband, i honestly have no idea how to hook it up, my y pipe on my truck has 6bungs for o2's, its got the precat, after cat and others are later in the y-pipe, which would be the best??
thanks for your help
tj
tj
SWINGRRRR
09-03-2015 07:49 PM
mr03silverado
09-02-2015 11:43 PM
