a few options, whats your pick ? 03 5.3 swap
#21
Now were talking. Im going to use this truck to tow my toyota prerunner. This wont be a racer, or 1/4 mile runner. Just a grocery getter/ toy hauler. A tune is definitely in order, for the time being I should be able to run off the stock pcm and larger injectors as you suggested. From what I understand, the ls6 is partially torn down, prepped for rebuild. He us asking for 3300 for everything complete accessories. Also comes with a 4l60e. Everything out of an 04 vette. How about reluctor wheel set up? I read that it is a 24 tooth set up. This should plug in like normal, correct?
#22
Yes it is 24 tooth reluctor same as your truck. You may ask if he will negotiate a lower price since all you need is the long block without the accessories and transmission. Also, if it is not assembled then you should be able to negotiate a lower price for that as well.
You can run on the stock tune and injectors for the time being but I would strongly suggest getting the correct tune and injectors on it as soon as you can. Even if it is not going to be a race truck it is still beneficial to have the correct tune and parts to support the new engine. My dad and I both saw about 2mpg improvement once tuned for the new engines, they just simply run better and more efficient with the correct parts.
#23
Engine is assembled, comes with ls1 intake. He wont split it up from the trans, but was asking 2800. If I can get it for 2500, think its a decent deal? Its at a shop and seller said the shop put it back together and everything is torqued properly, but that will be verified.
Closer_2001
Jul 21, 2015 03:25 PM
oharajo
Jul 18, 2015 09:24 PM
04BlackGmc
Jul 16, 2015 04:10 PM
