Fastest Truck List
Old Feb 4, 2005 | 10:47 AM
  #111
12sec.5.3's Avatar
Originally Posted by zippy
i don't believe you have an LS1 truck either, never seen a truck come with an LS1 in it.
Earth to zippy..... I believe all 4.8's, 5.3's, and 6.0's are ls1 based otherwise they would not be talked about 24/7 on "ls1tech.com". All 99+ trucks with a v8 Are ls1 based. What kind of vehicle do you have? If it's the s-10 in your pic. I'd like to know what kind of engine and mods do you have. Create a sig.
Old Feb 4, 2005 | 01:30 PM
  #112
Sport Side's Avatar
Cool
No need to argue the name. The 5.3 fits into the Gen. III family. Truthly, the 5.3L is not a ls1.
The ls1 is a 5.3 on steroids. (compression, more piston)
https://ls1tech.com/forums/attachmen...chmentid=14600
Old Feb 4, 2005 | 01:33 PM
  #113
Scream's Avatar
MOOBIES Moderator
I have an LS1 truck.
Old Feb 4, 2005 | 02:49 PM
  #114
12sec.5.3's Avatar
You are right sportside5.3 that's why I wrote "ls1 based".
Old Feb 4, 2005 | 06:55 PM
  #115
zippy's Avatar
the sonoma gt in the picture has been sold for a while. it was just another toy. current toy is an LT1 M6 camaro. if i own it through the summer i'll be impressed.
no need for earth to zippy, i'm well aware that the 5.3 is a gen III small block. i'm also well aware that LS1 is simply the RPO used for the 5.7 introduced in the vette. i never use the "based on" name, only what it is. if that were the case when i worked on an L31 should i referrence that to the original 265???
as for randy, i'm sure the hell not driving down that way. most sites require some time of video or timeslip and that's the idea behind the . if you posted either or simply had someone come in and say they seen the pass themself i'd have just left it alone. no need to be offended, times are questioned on the internet almost on a daily basis. any pictures of your truck? (no i'm not asking because i don't believe you have it, i just like pictures).
scream, you sure do. lololol
Old Feb 4, 2005 | 07:12 PM
  #116
Sport Side's Avatar
Cool
Todd. You got a digital camera perhaps? Just flash the board when Randy's times flash up
Or if you have a recorder, that'd be even better.
Old Feb 4, 2005 | 08:23 PM
  #117
slowprocess's Avatar
Originally Posted by 12sec.5.3
Damn it! I see I missed all the *** chewing. I'm gonna try my best to go to the track next friday with ya Randy. It's been a while since I've been. A good while. I was never abled to try the new converter in good weather. So I will hope for the best. As most of you know my all time best is a 12.81 with the vig. I've changed the converter to the tt3000. The only other change is the tires, from 26x11.50 to 26x10.50, which will probably do nothing. So, I'll hope for atleast a 12.9x so I can keep my screen name.
Slowprocess- what's up man? It's been a while. Anyways I see you got the eaton. Are you still spinning off the line? What tires are you running? If I were you i'd take a night at the track to feel the converter out. I had to do the same with my new one. Always get the tires nice and sticky for one. Try leaving all different ways. You know, try from an idle, let the engine cool, try from 1000, let it cool, try 1500, let it cool, try 2000, let it cool. Keep uping the rpm's until it pushes the brakes. Then compare all your 60' 's and that should tell you where your converter likes it. Hope this helps.
Bigkid- I know your out there. Noticed you got the truck back and running. Very impressive. Congrats! Are you satisfied with it yet?
What's going on, man? I've only been to the track once since the Eaton install, and it was doing its job. I didn't warm up the tires enough one time and got sideways my first pass, but I had no trouble on the other ones. I'm going to try what you said tomorrow night at the track. I'll get alot of passes at Greenville, so I'll get to do alot of testing. I really think I can get a better launch than the 1000rpm launch.
BigTex- I really think you're right. I'll try it out tomorrow night and post up some results. Wish me luck!
Old Feb 4, 2005 | 10:24 PM
  #118
litreddevil's Avatar
Banned
Here Is A Picture Randy's Truck
Old Feb 5, 2005 | 01:43 AM
  #119
zippy's Avatar
is that a gray color?
Old Feb 5, 2005 | 08:59 AM
  #120
Banned
I Can't Get It From One Section To This One Lkie I Said I Don't Sit In Front Of The Pc All Day I Just Try To Go Fast I Will Try To Pm All Of You With Pic.and Time Slip
