FAST or Victor jr LS1 intake ..
Old 01-22-2006, 08:29 PM
8ALTNG's Avatar
Ya but with the edelbrock there will be no chance of number 7 going lean like you do with the LSx style intakes. The runner will stop that
Old 01-22-2006, 08:33 PM
Kano's Avatar
Originally Posted by litreddevil
I was told that its not the intake that leans out number 7 but the fuel line set up,that is y i put the after market fuel lines and pressure regulator
I think when comparing the composite intakes to the old carb style intakes that there would be a difference in airflow bewtween the runners
only way to tell would be put o2 sensors on each primary and analyze the data
look at the truck intake, it has to go in, up and then back toward the front
I wonder whats happening in there at 6000+ rpm
8ALTNG's Avatar
Ya but if you look at the inside of a LSx intake, you can see that all of the air is pushed dirrectly to the back of the intake. There is nothing seperating it. This will cause you to have the number 7 go lean. The air hits the back of the intake and dumps into the number 7 1st. then it flows into the rest of them.
Then fuel might help in leaning it out, but the intake itself is a big part of the problem.
Old 01-22-2006, 08:37 PM
mattrem's Avatar
I see what you are saying about the LSX type manifold,
8ALNTG Which manifold did you get? the Victor Jr open plenum? I heard thats the one to use.
Old 01-22-2006, 08:42 PM
8ALTNG's Avatar
Ya that one or the GM Performance parts one. My mechanic (slowhawk) will be the one ordering it. He is the man wit the plan
Old 01-22-2006, 08:50 PM
mattrem's Avatar
I heard there was some problems with flow on the GMPP one. You can't beat Edelbrock, I know that Richard and I talked about he said their stuff was really good.
What does your setup include?
Old 01-22-2006, 09:07 PM
EL_3grab's Avatar
nothing tell now .. just make the plans go right ...
Old 01-22-2006, 09:42 PM
8ALTNG's Avatar
Built 4.8l lower end
LS1 Heads p&p's
216/2xx cam
edelbrock shorty header
FMIC
67mm STS (14-20+lns boost)
soon to be 60lb injectors
and a carb intake (probibly a edelbrock one)
Old 01-22-2006, 09:46 PM
mattrem's Avatar
LS1 Heads p&p's
216/2xx cam
FMIC
Sounds cool, Keep us posted
Old 01-22-2006, 11:17 PM
EL_3grab's Avatar
How about the Torque in Low end with this intake compared with LSX ...
Quick Reply: FAST or Victor jr LS1 intake ..
