FAST or Victor jr LS1 intake ..
what do you think :)
For What?
What is the setup??? I am going with a carb intake for acouple reasons.
1. I can fun F-Body style injectors 2. Cheaper than FAST 3. Will not lean out number 7 cylinder like other LSx intakes. |
The carb setups are running right with the EFI setups in terms of BOTH power and torque.
I dint realize that FAST made a carb setup for teh GEN 3/4 engines, I only thought Edelbrock did. peace Hog |
FAST doesnt make a carb setup. I am running a carb intake but with all of my electronics and a 90mm tb. no actual carb here :)
My vote is Carb intake plumbed for injectors and TB. :judge:
I thought about this for awhile before I got my FAST. I talked to Edelbrock and they said it doesn't start making power until 3500 rpm and you need a cam over .600 lift.
It could definately work, I have only seen it used with a turbo, such as 8ALTNG is doing. I was going to try it, but I got a good deal on my FAST.
Originally Posted by EL_3grab
Those two ..
I was told that its not the intake that leans out number 7 but the fuel line set up,that is y i put the after market fuel lines and pressure regulator |
