fast fuel plumbing
You have to buy a fuel pressure regulator to run the billet rails. Also the an fittings and hoses. I have a post, ill post it up. I think I spent about $400 on everything to run it. But I bought all earls products, you could buy wahtever brand you want. Hope this helps.
https://www.performancetrucks.net/fo...l-line-498265/
one more thing when i put in my injectors they seated to the bottom but its not very tight. is that normal? i know on my stock intake its a pain sometimes to seat them all the way. maybe i need a bigger bottom o-ring?
yep that was the issue. "lubed" them up and they snugged up perfectly. its a shame the instructions fail to mention the need for different o-rings. even the billet fuel rail instructions did not mention it.
