Fair head milling price?
Old Oct 30, 2016 | 04:18 AM
Jake75's Avatar
Originally Posted by Blown06
Do you just want them flat, or do you want to mill a mile off of them to raise the compression? Costs vary.
True, I had mine milled .010
Old Oct 30, 2016 | 06:36 AM
madmann26's Avatar
Why 243's? With milling it's going to rise the compression ratio and for a boost motor you don't want the compression ratio to high.
IMO - 317's would be better, cheaper and flow just as well as the 243 head.
Old Oct 31, 2016 | 04:11 AM
marineusmc4's Avatar
I was gonna have them milled to bring compression back to 9.5:1. Do you know what the compression is on them if I don't mill them?
Old Oct 31, 2016 | 04:12 AM
To raise compression. And to be flat lol
Old Oct 31, 2016 | 08:30 AM
madmann26's Avatar
What motor are you putting these on? The 243's have a small chamber and would bump your compression up as they sit. The 317's are the same head but with a 71cc combustion chamber, thus why they are preferred for boosted app's.
Old Oct 31, 2016 | 09:33 AM
Gbrown1320's Avatar
compression with a stock LQ4 and 317's is 9.5:1. If you swap the smaller chambered 243 heads onto the stock LQ4 you're looking at roughly 10.4:1, and that's without milling them at all.
Old Oct 31, 2016 | 10:51 AM
madmann26's Avatar
Exactly my point.
With 9.5cr, you're DCR (dynamic compression ratio) will be 15-16cr (this is good).
Treat DCR as how fast does it rev when you blip the throttle. With a pd blower, it's going to feel really really snappy.
Old Nov 1, 2016 | 01:29 AM
These 243s will be going on a 5.3 motor not a 6.0
Old Nov 1, 2016 | 01:30 AM
And I was wanting to keep the stock compression roughly the same in case I ever decide to take the blower off and go N/A again is all.
Old Nov 1, 2016 | 07:24 AM
madmann26's Avatar
With this combo and .030 milling, .051 headgaskets, your CR will be around 9.5:1.
You loose compression from the 5.3 to the 243 heads because the 243 has a larger combustion chamber.
The 5.3 head has the smallest combustion chamber of any stock ls type head.
