F/R Cross Drilled Slotted Rotors And Axxis Ultimate Pads Package Free S&H
#32
I know you guys are probably tired of me chiming in, but there has always been a compromise when using better pads. More often then not, dust and squeal are something you sometimes have to live with when using a performance pad. But as noted above a good break-in procedure will minimize it.
#34
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Originally Posted by dogger
I have these brake's on my camaro and will get them for my truck soon as my stocker's are starting to warp. this will squeal if you don't brake them in properly. however if you brake them in slowly and proply they make no more noise then stock brake's. I know this cause I didn't do this properly the first time so I replaced the pad's and broke them in properly without a single problem since. I now put on about 25k on them as well and pad's are less then half warn with aggressive driving.
#35
unredeemed,
as a tires guru tell me something. Two same trucks, same motor, same size and brand of tires. Only one has the cross drilled and slotted rotors. Which one is going to stop better at 90 MPH and by how many feet?
#36
Well Im thinking this is too good to let go by so I call the place the order and ask some Q's and................
They are in a meeting and have an answering service taking messages...
I call back an hour and a half later and............
They are still in a meeting and have an answering service taking message.
#39
Originally Posted by Whistlin00
Already having problems again i guess
