A/F for Alcohol
Old Feb 4, 2010 | 03:21 PM
dirt track racer 81's Avatar
Default A/F for Alcohol
Whats the ideal wot a/f for alcohol?
Old Feb 4, 2010 | 03:51 PM
Phantom's Avatar
11 Second Club
what kind of valve springs do you have?
Old Feb 4, 2010 | 04:06 PM
Coban's Avatar
Old Feb 4, 2010 | 04:10 PM
Black'Rado's Avatar
i read somewhere its from 7.1 to 9.1
Old Feb 4, 2010 | 04:12 PM
Wheatley's Avatar
Truck Sponsor
Stoich for Methanol is 6.5 A/F=1.00 Lambda
Stoich for Ethanol 9.0 A/F=1.00 Lambda
Old Feb 4, 2010 | 04:14 PM
1Bear's Avatar
It depends greatly on what type & concentration of alcohol, but here is a list of the stoichiometric air-fuel ratio's for different fuels to give you something to look at now. Typically the ratio will be between 7.1 to 9.1 for alcohol. Also pre-ignition can be problem unless the mixture is kept well on the rich side. The reason for this is that if the mixture is on the weak side it burns slowly and can still be so doing when the exhaust valve has opened which then becomes overheated. This in turn ignites the next charge before the correct time, the whole process becoming a chain reaction causing even more rise in temperature and so it goes on until the piston holes and other damage then follows.
Gasoline: 14.7
Natural gas: 17.2
Propane: 15.5
Butyl Alcohol: 11.2
Ethanol: 9
Methanol: 6.4
Hydrogen: 34
Hexa-Decane: 15
Diesel: 14,6
Old Feb 4, 2010 | 04:17 PM
Wheatley's Avatar
Truck Sponsor
Gasoline: 14.7
Natural gas: 17.2
Propane: 15.5
Butyl Alcohol: 11.2
Ethanol: 9
Methanol: 6.4
Hydrogen: 34
Hexa-Decane: 15
Diesel: 14,6
There ya go
Old Feb 4, 2010 | 04:26 PM
lol better than yours..
Gasoline: 14.7
Natural gas: 17.2
Propane: 15.5
Butyl Alcohol: 11.2
Ethanol: 9
Methanol: 6.4
Hydrogen: 34
Hexa-Decane: 15
Diesel: 14,6
yea i know what stoich for methanol is.. like for gas it 14.7 and we like to run 12.8 wot, when i go to strap this on the dyno what do I want to run wot?
Old Feb 4, 2010 | 04:43 PM
Wheatley's Avatar
Truck Sponsor
What type of Alcohol?
Ethanol,Methanol or what?
Old Feb 4, 2010 | 04:50 PM
itll be methanol
