Exhaust Temp Sensor
Old Dec 6, 2002 | 02:32 PM
IslandTahoe's Avatar
Default Exhaust Temp Sensor
Does anyone know if the oxygen sensors located infront of the cats measure exhaust temp also?
I would like to install an autometer exhaust temp gauge and hoping/praying that I can tap into a factory sending unit instead of having to mount an additional seperate sender.
Old Dec 6, 2002 | 03:03 PM
oxidizr's Avatar
Moderator / Sponsor
Default Re: Exhaust Temp Sensor
EGT - Exhaust Gas Temp is not measured by an O2....so you will in fact have to tap another sensor into your vehicle. An EGT probe, however must be placed within 1"-3" from the head for accurate readings. I have mine plumbed in to the air injection tube (which of course was deleted with the addition of the headers)with a block off plate.
Old Dec 7, 2002 | 10:03 AM
eallanboggs's Avatar
Why skimp. You should just run the same set up the Fuel and Alcohol guys run. Eight cylinders = eight exhast temp sensors, one on each header pipe. That way you really know what your engine is doing. Not just Bank 1 or Bank 2.
Corvette454l88
Sep 1, 2016 01:24 AM
ullose272
Aug 5, 2016 02:05 PM
pittman
Jan 19, 2016 07:06 AM
brandon6.0
Aug 19, 2015 07:48 AM
zblee
Aug 3, 2015 03:45 AM
