safest amount of boost
Old Dec 7, 2002 | 01:06 AM
redaddiction's Avatar
Default safest amount of boost
Whats the most boost i can run on my 5.3 i know the ati kit has like 8-9 and i'm looking at a turbocharger so should i be ok with that much boost? Also I'm going to need to upgrade fuel system what would be the best I want something i can grow with even if in the beginning it's overkill. Thanks
Marc
Old Dec 7, 2002 | 01:14 AM
1999stepside's Avatar
Default Re: safest amount of boost
Whipple told me that 10psi is about all the bottom end can take before you start having problems.
Kent
Old Dec 7, 2002 | 03:11 PM
ranwalk's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 1999stepside:
<strong>Whipple told me that 10psi is about all the bottom end can take before you start having problems.
Kent</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">it must depend on what mood they are in.i emailed stephen at whipple wanting to know what pulley i needed to run more boost.all he would say is not to run more than the 6pounds,that the engine couldnt take it. <img border="0" alt="[bullshit]" title="" src="graemlins/gr_bs.gif" />
probably best to run water injection with higher boost levels with no intercooler,or a good custom tune.9-10 pounds with an intercooler should be no problem.
Old Dec 7, 2002 | 03:20 PM
parish8's Avatar
single digit dreamer
i think max boost has alot to do with the type of blower, the ati is going to be able to boost prety high expecialy since there is very little boost down low. with a turbo set up set at 9psi you are going to get 9psi alot sooner and may have detonation problems. with the whipple 6psi is hard to do when it is hot on pump gas.
Old Dec 7, 2002 | 04:00 PM
BigTex's Avatar
Parish8 said it well.
zblee
Nov 11, 2015 12:41 AM
2500ZL1
Sep 12, 2015 03:50 PM
sTNT971
Sep 11, 2015 02:38 AM
06murder
Sep 4, 2015 03:54 PM
