Exhaust size for turbo 408
High on diesel fumes
Whta would you guys recommend exhaust-wise for a 408 with about 15 psi? Something in the 800-900 hp range? Right now I have the Corsa, 3" single. Trying to figure out what I'll need to go with when turbo time comes.
Are you wanting single or dual exhaust? I am thinking dual 3" would be sufficient while keeping enough backpressure for low-end.
Edit:hmm I actually do not know too much about your motors and just thought that they actually use a y-pipe. I guess 4-5"
5" would be a bitch to fit. 4" is prety tight too.
i had a 4" down pipe with a 4" cut out and from there back 3.5". i had 2 small bullets inline with a dump infront of the rear tire and it was very quiet.
with that set up there was a significant gain in hp with the cut out open. at 15psi i bet 50+rwhp running it thru the exhaust.
You can get a Dmax 4" turbo back kit from warpspeedperformance for under $300. I cut just one kit up and made a 4" for my cummins and I made 4.8T a 4" catback with what was left. There is a ton of pipe and bends in those kits.
Stainless Works
Apr 10, 2016 04:34 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
GMCtrk
Jul 17, 2015 06:39 PM
