Tip for people doing cam installs
Old Jan 27, 2004 | 11:04 AM
99 2500's Avatar
Default Tip for people doing cam installs
When I was almost finish with my cam install, I did the following to avoid all the noise the valvetrain makes from being dry of oil. I left all of the spark plugs out, left the main connector for the coil packs disconnected and removed the fuel pump relay, I then turned over the motor with the starter for about ten seconds until I saw good oil pressure. After that I put in the plugs and reconnected everything and it started right up with no valvetrain noise. I thought I would mention this b/c it worked good for me.
Old Jan 27, 2004 | 11:46 AM
whitez71's Avatar
I believe you can also put your gas pedal to the floor and crank it without it providing any fuel. It is a mode the pcm goes into for starting a flooded engine.
Old Jan 27, 2004 | 12:10 PM
Yelo's Avatar
Yeah...but if you didn't have that sucker on the floor it would REALLY suck, an instant 5000rpm's WITHOUT any oil on the cam or lifters...stuff would go in a serious hurry
Stainless Works
Nov 20, 2015 08:55 AM
The_W
Oct 28, 2015 09:00 PM
all_individual
Oct 10, 2015 10:09 PM
mr03silverado
Jul 17, 2015 02:15 PM
all_individual
Jul 13, 2015 11:01 AM
