Exhaust problem!
Old May 27, 2008 | 10:03 PM
timmer1's Avatar
Default Exhaust problem!
Hey guys, just thought I'd see if anybody else has run into the problem I had over the weekend. I finished putting the cam in and went thru the suggested heat cycles, so it was all broke in. I got on it a few times on the way to my cottage and it got really loud. I looked under the truck, and the exhaust blew off from my pacesetters. I had the pipes slip over with a clamp on each side. I can't have too much backpressure, straight pipes out of the passenger side. How do you guys keep your exhaust on? I was planning on running a couple 40 series flowmasters and with the extra added backpressure, I would think it would be more prone to blow the pipes off again. Let me know what ya think. Thanks. Tim
Old May 27, 2008 | 10:12 PM
green6.0's Avatar
Never heard of that. Are you sure they were on there tight?Not being a smart *** but it could happen...
Old May 27, 2008 | 10:16 PM
timmer1's Avatar
yeah, I used an impact gun to tighten them, which I assume would be enough, but maybe not.
Old May 27, 2008 | 10:21 PM
2005 Silverado's Avatar
SPAM HUNTER
you could have over torqued them and stretched the bolt...
Dustin
Old May 27, 2008 | 11:12 PM
SpoolinChevy's Avatar
Tighten them without the impact, Like they said, im sure it was probably over tightened.
Old May 27, 2008 | 11:25 PM
viciousknid's Avatar
Where's the Beef?
Agreed. I stripped one out with a ratchet. Didn't know my own strength i guess.
Prefer using Band Clamps instead of C clamps. I used them to patch up my exhaust after the dealership had to cut the crosspipe off to change my tranny. Leaks a lil because of the gap there is from cutting the pipe off but it holds no problem.
Old May 27, 2008 | 11:29 PM
SPAM HUNTER
Those work good for an easy fix! I haven't used them, but i have seen alot of people who have.
Dustin
shawn96gmc
May 17, 2016 04:15 PM
pittman
Jan 19, 2016 07:06 AM
JFortner5
Aug 20, 2015 06:13 PM
Jake99
Aug 8, 2015 07:56 AM
Suburban2500
Jul 13, 2015 09:57 AM
