Exhaust help needed!!!!
Old Aug 20, 2010 | 03:56 AM
russ3825's Avatar
Default Exhaust help needed!!!!
Have an 09 Silverado ECSB with the 5.3 and will be adding the following. ARH Longtube headers w/ 1 3/8" primaries, Magnacharger TVS1900, Pat G Speced cam, Performabuilt LVL 2 transmission, and it will be dyno tuned. The last thing I need to figure out is my exhaust, performance is my main concern. I will be running true duals with an x-pipe and Hooker Aerochamber mufflers. With my planned mods, should be pushing around 450 to 500 rwhp. My problem is im not sure what size pipe to run on my exhaust, to big and I lose low end torque. To small and im not getting everything out of my motor and mods that I should. What size should I run 2.5" or 3", and is this the best option for me to meet my performance goals. Any other proven suggestions are greatly appreciated.
Old Aug 20, 2010 | 11:40 AM
budhayes3's Avatar
PT's Slowest Truck
Well you're going to want bigger than 1 3/8" primaries that's for sure! Pretty sure that you meant 1 7/8" I'd think that dual 2.5's would be plenty adequate for your setup IMO, but I'm curious to see the other suggestions that you get...
Old Aug 21, 2010 | 05:08 AM
russ3825's Avatar
Oops I meant 1 3/4'' primaries, do you think I really need 1 7/8" primaries?
Old Aug 21, 2010 | 08:25 AM
budhayes3's Avatar
PT's Slowest Truck
No, I believe that 1 3/4 should suffice IMO
Old Aug 21, 2010 | 11:28 AM
terravast4's Avatar
I am running my stainless works 1 3/4 into 3" duals. high flow cats after the trans crossmember into 3" x-pipe then straight into two Borla round xr-1 mufflers then torndowns right after that. plenty of low end torque and lots of top end too. Quiet at idle but when you get on it it sounds awsome.
Old Aug 21, 2010 | 08:34 PM
schino's Avatar
terra got any pics of that? kind of thinking of doing that on my truck. gotta change it up and add cats
Old Aug 22, 2010 | 01:43 PM
terravast4's Avatar
I have a few pics in my profile but not the greatest......truck is too low to get good pics.
Old Aug 22, 2010 | 02:08 PM
skeet's Avatar
1 7/8s headers 3" duals
ZONES89RS
21
Sep 24, 2015 05:58 PM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
Aboss
Jul 9, 2015 10:28 AM
Sbrown06
Jul 9, 2015 09:21 AM
