Exhaust Drone Fix
Old Jun 15, 2009 | 05:36 PM
  #51
therock's Avatar
Fix = Corsa!
Old Jun 15, 2009 | 06:13 PM
  #52
thunder550's Avatar
High on diesel fumes
Originally Posted by therock
Fix = Corsa!
Been there, had one....had to go to a true dual setup so I couldn't use the Corsa anymore.
Old Jun 15, 2009 | 07:58 PM
  #53
kbracing96's Avatar
Originally Posted by thunder550
Bringing this one back...has anyone else tried this? I'm thinking about giving it a shot.
Try it, then you can tell me if it works!
Old Jun 15, 2009 | 10:55 PM
  #54
thunder550's Avatar
I may just do this. Need to spend a few minutes digging around under the truck to see where I can fit two 35" tubes. My drone is really bad around 1500-1600 RPM. I would love to get rid of it.
Old Jun 15, 2009 | 11:59 PM
  #55
TX Tahoe Z71's Avatar
Do the branch resonator and post up! I already tried cutting the pipe and dumping
Old Jun 17, 2009 | 11:52 PM
  #56
I Drive a 4.8's Avatar
I just turn the radio up to about 15 or 20, and the two 10s seem to cancel that out pretty well... or cover it up... whatever. I can't hear it though.
Old Jun 18, 2009 | 09:47 AM
  #57
kbracing96's Avatar
Mine is 2100+.... :o\
Old Jun 18, 2009 | 10:14 AM
  #58
dhpro's Avatar
Originally Posted by skyhighsami
I was seriously thinking about cutting the cats off my truck but didn't want to because it would be so loud and drone so badly. I like the Magnaflow mufflers because they are stright through but they seem to drone alot. I will seriously try this and see what happens.
I have gutted cats and Mag mufflers on my true duals...drone is really bad, and its really loud when I stomp on it! Sounds like open pipes or an old ChrisCraft...
Old Jun 18, 2009 | 04:00 PM
  #59
shupe's Avatar
After I gutted the cats on my '99 rc 5.3 w/ si/so 5x12x18 magnaflow the drone was terrible. Took a trip to Omaha the next day it was unbearable between 1800-2200 rpm. Ended up wearing ear plugs on my trip. Once I got back I ended up recutting the hollowed cats and welding a pipe that ran through the cat shell. It reduced the drone considerably!
Soon their after I installed a set of catless LT's w/ a si/so 5x12x22 magnaflow while I was under there, work end result was a quiet drone less exhaust.
Good Luck!
I think those were the right dimensions of the mufflers.
Old Jun 21, 2009 | 11:22 PM
  #60
TS77's Avatar
Here's someone's setup: http://img184.imageshack.us/i/resonatoreg7.jpg/
I dont know if i posted this a while ago, but there was another forum that was going over this topic about resonance or drone. http://forums.corral.net/forums/show...ight=resonance You can read about what they tried and what did or did not work before you try anything yourself. Hope you can find some info to help.
