Everyone inside.
So okay when i had my blower on my old truck and was ahving problems a lot of guys were liek you should just done a head and cam setup on the 6.0 with a 125 shot...so okay now i have a truck with a 4.8 and i have and lq4 sititing in my garage....so what head and cam setup should i run? im clueless on which route to go?....
my goal: 12s on motor 11s on nitrous. is that to much to ask for? its a rcsb....i dont mind having a very aggressive setup im not looking for anythign to tame as far as a cam goes...so ill just list some supporting mods im giong to have and maybe u guys can help me out.
-eaton posi.
-2/4 or 4/6 drop
-cal tracs
-stall between 3200-3800 depending on what u guys reccomend.
-Dr's on some denali wheels and et streets on my stocks
-ASM LT's
-Flexa- lite fans
-Hp tuners
-42lb injectors
-magnaflow
-possibly qa1's
-eaton posi.
-2/4 or 4/6 drop
-cal tracs
-ASM LT's
-Flexa- lite fans
-Hp tuners
-42lb injectors
-magnaflow
-possibly qa1's
Looks like a combination simillar to what Slowprocess has, and he has been 12.54 with his and only mild head work. I would go with a simillar cam and a set of GTP heads and be shooting for 12.2x or so on the motor. There are a bunch of good options as far as heads go, but there are some F-body's around here with heads (GTP) and cam only running real, real strong (low 11's on the motor and better!). Their customer service is good to, and they will spend a ton of time talking to you and helping you with the specifics. You should be able to spray that down to a 11.5x no problem. I wouldn't go much higher than 3000 or 3200 on the converter, especially since you are going to be fighting traction.
Do you still want it to pass the oppressive Califronia smog?
