Escalade 6.0 vs HD 6.0 Why the HP Differences?
Old Nov 16, 2001 | 10:15 AM
Jason 98 TA's Avatar
FormerVendor
Default Escalade 6.0 vs HD 6.0 Why the HP Differences?
Anyone know why the Escalade claims more HP than a 6.0L in a HD?
Thanks
Old Nov 16, 2001 | 10:33 AM
GTO Forum Director
Default Re: Escalade 6.0 vs HD 6.0 Why the HP Differences?
Differences in intake and exhaust plumbing I believe.
Old Nov 16, 2001 | 10:36 AM
really slow truck's Avatar
i thought it had a different cam and heads??? <img src="images/icons/confused.gif" border="0">
*edit* i dont know about different heads and cam, i just remember hearing that somewhere. But, i just looked at their site and it does have 10:1 compression, compared to the normal 6.0L's 9.4:1
[ November 16, 2001: Message edited by: really slow truck ]</p>
Old Nov 16, 2001 | 10:40 AM
DV8's Avatar
DV8
[quote]Originally posted by CMNTMXR57:
<strong>Differences in intake and exhaust plumbing I believe.</strong><hr></blockquote>
Sounds about right. I don't know about the heads and cam though. Caddy needs the new HP rating to compete against the Navigator.
Old Nov 16, 2001 | 10:56 AM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
Jason, check the compression ratios between the two.
Caddy = 10:1
Truck = 9.4:1
Different pistons & more aggressive PCM tune from the factory. Everything else is the same.
Old Nov 16, 2001 | 11:11 AM
Neil 6.0's Avatar
Also, the Caddy might have a slightly different head (milled for more compression?), but don't quote me on that. I seem to remember reading something about LQ9 heads.
Old Nov 16, 2001 | 01:00 PM
99RedHawk's Avatar
What kind of vehicle is Jason building this motor for ?
I personally thought that cadi just rated the HP higher...My 6 litre 4x4 makes about 260 and 300 RW Torque stock... Lot of drive trane loss with 3/4 ton 4x4 though..I also have the hybrid ls6 heads with 9.4-1 comp.
Old Nov 16, 2001 | 01:49 PM
Neil 6.0's Avatar
I was wondering if you were still alive Brooke. <img src="images/icons/tongue.gif" border="0"> Jason is wanting to put a 6.0 in his 2000 Chevy 1500 stepside. <img src="images/icons/smile.gif" border="0"> Have you been to the track recently with your HD?
Damn I wish Cadillac would just tell us where the extra HP is coming from. <img src="images/icons/mad.gif" border="0">
Old Nov 16, 2001 | 02:03 PM
brookes loss is about 15% through the drivetrain, so that seems about right. I would like to see an actual stock dyno sheet for an escalade, even though i dont think that will happen anytime soon i think it would show alot as for overrating. If the part numbers are the same then i would say its the more aggressive ecm and then milled heads (unless there is anything else to raise it?). even then, 45more hp??? thats quite a bit from 6/10ths of a point on compression and new ecm. Im thinking they do that, but ALSO over rate them. i dunno...
bryan
Old Nov 16, 2001 | 05:47 PM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
Update! Ok we found out that in fact the 6.0L (LQ9) does have a different piston than the 6.0L (LQ4) I wish I knew if it was a cast aluminum or a hypereutectic piston though?
The cylinder heads have the same part number on both engines also. The camshaft is showing the same part number, but I really wonder if that is right.
