Eradispeed rotors / Baer Claw systems GP
Old Dec 11, 2002 | 01:03 PM
tbyrne's Avatar
Default Eradispeed rotors / Baer Claw systems GP
<img src="http://www.tbyrne.com/trucks/Baetrucks.jpg" alt=" - " />
We have a GP running that covers all Baer Eradispeed rotors and Baer Claw systems. Eradispeed info is listed below. Let me know if anyone needs info on the Baer Claw upgrades.
Baer Brake Systems, the leader in automotive braking systems is proud to announce the introduction of the EradiSpeed+1 upsized rotor package for the latest generation of GM ½ ton truck and SUV applications. These performance rotors feature LITE™ (Low Inertia / Thermally Efficient) technology. Two piece rotors have anodized billet aluminum hats with re-useable stainless N.A.S. aircraft hardware. Designed specifically for use with popular 18-22-inch wheels, EradiSpeed+1's feature massive 14" diameter rotors front and rear, along with all the custom hardware to make installation quick and easy. EradiSpeed+1 rotors are also "cosmetically enhanced" with cross-drilled, slotted and zinc washed surfaces.
Cast from a high friction iron alloy, EradiSpeed+1 rotors are designed with more mass for heat absorption, are directionally ventilated for increased pumping efficiency and feature billet or forged aluminum centers, which reduce overall rotor weight. By eliminating the weight at the center of the stock iron rotor, Baer is able to cast the rotor with more mass in the "fire path," (where the pads contact the rotor,) allowing substantially more heat to be absorbed into the rotor. Balancing and heat-treating, coupled with the increased pumping efficiency of directional vanes (vents), ensure that EradiSpeed+1 rotors deliver substantial performance benefits.
Many of today's vehicles using larger wheels experience drastic reductions in braking ability due to the additional weight of the wheel...sometimes up to 35 pounds per wheel. With its larger rotor size, EradiSpeed+1 rotors are able to regain even more than the original braking performance. Best of all there is no need to bleed the system after installation.
When you inspect the quality, appearance, performance and durability, you'll see that Baer's EradiSpeed+1 rotors are a desirable and high value upgrade. In addition, Baer is so sure of the EradiSpeed's functional merit, that it provides a Limited Lifetime Warranty against warping. No other performance rotor manufacturer on the planet offers such protection.
For even greater stopping power, Baer also offers complete Baer Claw brake package systems, which include either the Alcon or PBR calipers.
2301028
1999-'03 Front EradiSpeed front rotor package (Plus one) - fits GM 1/2 ton Pickups (2WD and 4WD) (NOTE 6+ 7)
2301028
2000-'03 Front EradiSpeed front rotor package (Plus one) - fits GM 1/2 ton SUV (2WD and 4WD) (NOTE 6 + 7)
2302024
2000-'03 Rear EradiSpeed rear rotor package (Plus one) - fits GM 1/2 ton SUV (2WD and 4WD) (NOTE 6 + 9)
(6) Plus One - includes 14" 2 pc rotors and caliper anchor plates
(7) REQUIRES aftermarket wheels - see template Z077P at www.baer.com
(9) REQUIRES aftermarket wheels - see template Z235P at www.baer.com
This GP will be ending on 12/23 and 10 or more orders are required. Just e-mail tbyrne@tbyrne.com for the GP prices. Be sure to let us know what kind of vehicle you are interested in putting brakes on (this GP covers many different vehicles).
Have a good day,
Tom
Old Dec 11, 2002 | 03:53 PM
Brandon Boomhauer's Avatar
Default Re: Eradispeed rotors / Baer Claw systems GP
throw some info on the claw system in....
btw do they include new pads? I posted last night about better braking, glad to see this.
Old Dec 11, 2002 | 08:52 PM
tbyrne's Avatar
There are two packages available for the 1999-'03 1500 series trucks and 2000-'03 SUVs -
PRO+ - Is Baer's top-of-the-line 4 piston system. Standard with 13.5" (or optionally, 14") diameter x 1.25" thick, Alcon 48 vane directionally ventilated rotors. PRO+ systems deliver outrageous braking performance and repeatability simply not available from other 4 piston systems. PRO+ packages are only eclipsed by Baer's own EXTREME+ systems. PRO+ systems provide a significant upgrade for Vipers, Corvettes and Mustang Cobra or Cobra "R" models. Although configured for road use in every way, PRO+ systems are a logical choice for track worthy performance on muscle cars, top flight hot rods or even one off concepts.
EXTREME+ - Features Alcon, billet aluminum,6 piston, staggered bore, radial mount calipers as first used on Trans-Am cars, but which have been homologated for street use. EXTREME+ systems are the most potent road going brake systems available from any source. Alcon dominates Trans-Am, with 6 consecutive Championships and wins in all but tow races in six years. So don't confuse billet Alcon with massive 7793 series pads and the 6 piston units offered by any other company. Alcon 6 Piston,
Our regular retail for these is $2699./$3699. E-mail for the GP prices if you are interested.
.J.
20
Mar 4, 2016 03:03 PM
FlowmasterMufflers
Nov 24, 2015 01:00 PM
cousblake11
Sep 9, 2015 06:52 PM
Alco
Sep 4, 2015 04:08 PM
