enough backpressure???
Old Sep 16, 2005 | 11:35 AM
Lone Chev's Avatar
Default enough backpressure??? RADIX
Finished up 6.0l swap thinking about my next mod.. Most likely will be headers. Thinking about just doing some shorty's with cutouts in place of the CATS. Have heard these motors need some back pressure but with the radix what do you guy's think? Will there be enough with the cutouts open? or will this just hurt my performance?
Old Sep 16, 2005 | 11:51 AM
nightmarechevy's Avatar
With a RADIX you will probably want your exhaust to flow better rather than having more backpressure. I don't have FI so I couldn't tell you but that would be my opinion. Maybe someone will chime in and help out a little more.
Old Sep 16, 2005 | 01:44 PM
zippy's Avatar
when you run the cutouts you're probably going to have to drive it for a few miles. occasionally some have a problem with running lean if you just open them and make passes.
Old Sep 16, 2005 | 01:47 PM
Lone Chev's Avatar
I did not know that thanks. Kinda figured the PCM would have to adapt to them.
Old Sep 16, 2005 | 02:11 PM
Fogle07's Avatar
i drove mine with open headers on it to the muffler shop and it barely wanted to run for a little bit but then it started running good. it felt real good with open headers and sounded awesome. i will be putting cut outs on mine for sure
Old Sep 16, 2005 | 02:41 PM
Lone Chev's Avatar
Say you did want to open them at a stop light just for a quick run... could you tune for that lean condition with the tow/haul button? just an idea
Old Sep 16, 2005 | 02:44 PM
Fogle07's Avatar
i dont think you can adjust anything but tranny stuff with the tow/haul button.
Old Sep 16, 2005 | 04:16 PM
TXsilverado's Avatar
i think you can set different stuff with the tow haul button. otherwise why would waitforme make it the tow/haul *** button
Old Sep 16, 2005 | 04:26 PM
I think it is tow/haul *** because the shift points and maybe even the shift firmness are more for racing and not everyday driving. I am pretty sure that fogle is right though and you cannot change anything else.
Old Sep 16, 2005 | 04:33 PM
Jeff Alexander's Avatar
once you go forced induction backpressure doesnt matter. your forcing air into the motor so the faster you get it out, the faster in comes in. Its different with N\A vehicles.
