Engine swap, transmission fluid leaked out
Old Apr 29, 2007 | 09:52 AM
Lurius's Avatar
Default Engine swap, transmission fluid leaked out
Is it normal for some transmission fluid to leak out of the front of the transmission while removing the motor from the truck?
-Lurius
Old Apr 29, 2007 | 12:31 PM
Lurius's Avatar
came out of tranny dipstick tube.
-Lurius
Old Apr 29, 2007 | 01:06 PM
KySilverado's Avatar
If the dip stick tube was removed and the tranny tilted enough it would leak out. If the tranny were kept relatively level and it leaked out chances are it was over filled.
Old Apr 29, 2007 | 03:11 PM
Lurius's Avatar
Last time it was filled was by GM when they replaced the tranny for me, but yea, we tilted it a bit.
Thanks,
Lurius
Old Apr 29, 2007 | 03:42 PM
Nick™'s Avatar
yeah, as Ky said, not much should come out if any. when you remove the diptube while pulling the motor you leave a big hole for the fluid to leak through, the level isn't far below that level so if it isn't kept level the fluid will come out.
Old Apr 29, 2007 | 05:27 PM
BlownChevy's Avatar
blownerator
25 Year Member
perfectly normal.
GrooveCityZ71
Aug 31, 2015 12:05 PM
Ketis
Jul 23, 2015 12:37 PM
Mark_k
Jul 9, 2015 12:37 AM
Mzay
Jul 6, 2015 11:03 PM
Nimoryan
Jul 5, 2015 03:50 PM
