Engine swap, SORT OF?
Old Jan 22, 2010 | 10:52 PM
gxrior's Avatar
Default Engine swap, SORT OF?
I have a 2001 silverado with a 6.0.
I am looking to get a little more out of it when I replace it. (somewhat soon, just turned 200K)
I want to replace it with a 6.0 from a newer year and or model to hopefully get more HP!
Will any of the newer years/models plug right in with little or no mods needed to the computer, harness, or other components?
What is the best and/or easiest combo?
THANX
Old Jan 22, 2010 | 11:25 PM
Coban's Avatar
You need a tune, thats it. There are many threads on the swap....
Old Jan 23, 2010 | 11:04 AM
gxrior's Avatar
Is there a chart somewhere that shows what will plug right in and what mods are needed to complete the swap?
6.0 to 6.0 and/or 6.0 to 6.2?
Old Jan 26, 2010 | 02:29 PM
JJB's Avatar
JJB
do search on this mostly its the intakes return style fuel vs returnless you should be able just to swap over youre intake system now...most sensors plug right up I think some years had a difffernt crank senor but you could use the one of the old 6.0...as far as power goes you could hop up any 6.0 to do what you want , 317 heads are good, 706 if ou want higher compression ...you might just want to rebuild youre current set up ....cam it . larger ingectors, tune ...LTs , stall if needed could be small and go
Old Jan 26, 2010 | 08:27 PM
The_Rizzle's Avatar
the crank sensor changed to 58x at some point, however, i dont think there was many improvements on the 6.0 besides the lq9 and the new style intake. If you do use a 58x crank trigger engine, Im pretty sure Lingerfelter sells a conversion module to make it a 24x signal.
Old Jan 28, 2010 | 09:15 PM
rubrhammer's Avatar
from what I've read the 58 tooth wheel was introduced in 2004.
Bob
Old Jan 29, 2010 | 11:37 AM
pasadenaman's Avatar
That 58x to 24x part number is L460065397. I think they call it Lingenfelter TRG-001
I had to get one for my ly6 project.
ARC
57
Feb 21, 2022 10:54 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
04BlackGmc
Jul 16, 2015 04:10 PM
Mzay
Jul 6, 2015 11:03 PM
