engine swap 4.8 to 8.1 how hard is it
Old Nov 28, 2010 | 08:24 AM
billy1977's Avatar
Default engine swap 4.8 to 8.1 how hard is it
I have a 2001 gmc reg. Cab with stock 4.8 found an 8.1 how hard
will it be to swap it out will the stock trans. Hold up
thanks for any help
Old Nov 28, 2010 | 09:41 AM
silver-mod-o's Avatar
Hunt&Fisherator
I suggest using the search feature for a few days for this one
Buuuuut- you'd be better off $$ wise sticking to the small block LS family, and your stock trans (assuming it's a 60E) would be a good breakfast for that 8.1
Old Nov 28, 2010 | 10:00 AM
dmelvin's Avatar
It's very true... The biggest motor the 60E is mated to is the 5.3L for a reason, it's not built to take much more than the 5.3 can dish out. Putting an 8.1 in front of a stock 60E would turn your transmission into just a spray of transmission fluid and loose chunks of metal. If you're going to do an engine swap, it should probably go hand in hand with a tranmission upgrade as well.
Old Nov 28, 2010 | 10:35 AM
budhayes3's Avatar
PT's Slowest Truck
Yessiree, if you could get an 8.1 to bolt to a 60E, I doubt that the 60E would make it out of the driveway lol. But just to clarify, the 65E, which is basically a 60E with 5 pinion planetaries, came joined to the LQ9 6.0 in the SilvySS, VortecMax, etc.
If you want to swap big cubes into a GMT800 truck, look into a 6.0, or a stroker such as a 408, 418, etc, and if you go much more than a NA 6.0, plan on swapping in an 80E or once again you will have a trail of 60E behind you
GrooveCityZ71
Aug 31, 2015 12:05 PM
Ketis
Jul 23, 2015 12:37 PM
Cowboy17
Jul 9, 2015 08:22 PM
Mark_k
Jul 9, 2015 12:37 AM
Nimoryan
Jul 5, 2015 03:50 PM
