HELP.. Truck will not start after 5.3 swap..
Old Nov 26, 2010 | 03:25 PM
Low02's Avatar
Default HELP.. Truck will not start after 5.3 swap..
Okay, trucks a 02 V6 Silvy, 5.3 is from 02 as well, PCM is from a 02 GMC. I changed the VIN, disabled VATS, and flashed a 5.3 tune into it, still no fire.... All 144 grounds are hooked up, crank sensor, cam sensor, etc.... I even took the fuse box from a 5.3 truck and swapped em and still nothing. Im a newb at tuning, so bare with me. This is getting really frustrating, and i dont know where to go from here. Any help is appreciated. Thanks, Eric.
Old Nov 26, 2010 | 03:39 PM
silverz28camaro's Avatar
Does it crank? spark? fuel pressure,...... all these are info we need to help ya out
Old Nov 26, 2010 | 09:03 PM
rickjamesCC's Avatar
Well dude I was trying to figure out the same thing I was playing around on my Hp tuners and what might be the security relearn, try going in under flash and try relink vats!
Old Nov 27, 2010 | 01:05 AM
Low02's Avatar
Originally Posted by Low02
Still no fire..
Yes, it cranks, no it does not have spark.
Old Nov 27, 2010 | 01:06 AM
Low02's Avatar
I did the relink VATS also. Still nothing..
Old Nov 28, 2010 | 06:32 PM
Well I will tell you that you could have dealership load a tune and relink everything, when my truck was turbo charged. I went back to NA I had the dealership reload a 5.3 tune, I saved it on HP tuners before I put it back to stock and then when I put everything back I loaded the tune and it worked perfect I asked him at the time he said all he needed is a VIN# and about the same year with the motor you want to use, just look on autotrader for VIN's or the vehicle you got the engine from!
wrb002
Aug 31, 2015 12:00 PM
chevyl33
Aug 24, 2015 08:21 AM
cams 98 silverado
Jul 31, 2015 07:36 AM
steves86ta
Jul 28, 2015 10:21 AM
black6spdz
Jul 16, 2015 01:32 AM
