Engine Specs (seen it before can't find it)
Old Jan 24, 2006 | 09:37 AM
Injected1's Avatar
Default Engine Specs (seen it before can't find it)
Can someone help me out? I am looking for Bore and Stroke on the GM Truck engines...can someone help me out with this?
Old Jan 24, 2006 | 09:51 AM
Richard@WCCH's Avatar
FormerVendor
Here's what I have:
Vortec 4.8l 293.35cid Engine code: LR-4
Bore = 3.780” (96.01mm) Stroke = 3.268” (83.00mm)
Compression Ratio = 9.5:1
Factory Rated Horsepower = 270
Factory Rated Torque = 285 ft/lbs
Casting #’s 706 & 862
Combustion Chamber Volume = 62cc
Intake Port Volume = 205cc
Exhaust Port Volume = 77cc
Vortec 5.3l 325.16cid Engine code: LM-7
Bore = 3.780” (96.01mm) Stroke = 3.622” (92.00mm)
Factory Rated Horsepower = 285
Factory Rated Torque = 325 ft/lbs
Vortec 5.7l 345.7cid Engine code: LS-1
Bore = 3.898” (99.0mm) Stroke = 3.622” (92.00mm)
Compression Ratio = 10.1:1
Factory Rated Horsepower = 350
Factory Rated Torque = 375 ft/lbs (equipped with manual trans)
360 ft/lbs (equipped with automatic trans)
Casting # 241
Combustion Chamber Volume = 67cc
Vortec 6.0l 364.13cid Engine code: LQ-4
Bore = 4.00” (101.6mm) Stroke = 3.622” (92.00mm)
Compression Ratio = 9.4:1
Factory Rated Horsepower = 300 to ’01. 345 to ‘03
Factory Rated Torque = 360 ft/lbs to ’01. 375 to ‘03
Casting # 317
Combustion Chamber Volume = 72cc
Intake Port Volume = 207cc
Exhaust Port Volume = 76cc
Vortec 5.7l 345.7cid Engine code: ZO-6
Compression Ratio = 10.4:1
Factory Rated Horsepower = 405
Factory Rated Torque = 400 ft/lbs
Casting # 243
Combustion Chamber Volume = 65cc
Intake Port Volume = 211cc
Hope this helps.
Richard
Old Jan 24, 2006 | 10:26 AM
Injected1's Avatar
perfect...even more info than I needed
GrooveCityZ71
Aug 31, 2015 12:05 PM
JFortner5
Aug 12, 2015 08:46 PM
OLD BULL
Aug 1, 2015 05:00 PM
oharajo
Jul 18, 2015 09:24 PM
NuckenFuts
Jul 9, 2015 08:45 AM
