Engine Problem?
Old Jul 27, 2005 | 01:11 PM
Fogle07's Avatar
Default Engine Problem?
ive been hearing what sounds like an exhaust leak for a little while now so i checked all my exhaust and my header gaskets and everything is fine. so my question is could i have a lifter tapping or some other problem in the engine?
Old Jul 27, 2005 | 01:24 PM
LVSTOGOFST2002's Avatar
That is standard for a lsx engine, a large marjority of them make a lifter tapping sound. Don't be alarmed. Unless, it's not only doing it at idle or just off idle?
Old Jul 27, 2005 | 01:27 PM
Fogle07's Avatar
cant really hear it at idle. the faster you go the more you hear it.
Old Jul 27, 2005 | 01:36 PM
white1's Avatar
Mine was doing that. I pulled my push rods, about 7 were plugged
Old Jul 27, 2005 | 01:39 PM
Fogle07's Avatar
plugged? i just put a cam in my engine about 4000 miles ago and the pushrods were clean. i changed my oil saturday and there was some shavings on the oil plug. there were some on it the time before also.
Old Jul 27, 2005 | 05:41 PM
nightmarechevy's Avatar
Mine does the same after the header install, runs fine though and sounds normal at idle. I think it is just a leak at the collector, I can pop the hood and rev it and it sounds just fine but makes a little noise when I'm driving.
Old Jul 27, 2005 | 06:05 PM
CAMMIN03''s Avatar
Banned
Did you swap springs????
I have the Ls6 springs and they are alittle noisy..
But the 918's are really noisy.... My buddy has them.....
Old Jul 27, 2005 | 06:31 PM
budhayes3's Avatar
PT's Slowest Truck
Check out this thread: https://www.performancetrucks.net/fo...d.php?t=344989
I've always had some noise from my engine since day one, just seems to have gotten louder since my cam and spring install (and I have a relatively mild cam). I've always heard it in the cab, kinda right at my feet. Under the hood, while revving the engine and holding the rpm's up, it's very noticeable. I've tried both Comp 915 springs and LS6 springs, and the noise still remains constant...Harland Sharp roller rockers didn't make a difference in the noise either. Runs great though.
Old Jul 27, 2005 | 07:27 PM
Kano's Avatar
that doesnt sound good
wonder where thats coming from
Old Jul 28, 2005 | 06:33 AM
Fogle07's Avatar
i dont know it makes me wonder how much longer its going to hold up. i believe the specs on the cam are 212/218 .522/.529 lift. i have the stock springs in it still.
ferrellrooster
Mar 6, 2025 03:22 PM
Wareagle23
Aug 8, 2015 10:06 AM
Jake99
Aug 8, 2015 07:56 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
Mzay
Jul 6, 2015 11:03 PM
