Engine prelubing
Old Apr 30, 2012 | 10:17 PM
HRV-LS1's Avatar
Default Engine prelubing
Got a remanufactured lm7. Need to prelube it. Don't want to buy a $250 preluber. Someone told me to pour oil over the rockers and then crank it until I have good pressure. Does that sound ok? Any other ways of doing it?
Thanks.
Old Apr 30, 2012 | 10:22 PM
oakley6575's Avatar
Thats what I did. It took three good cranks before it showed oil pressure. I fired it up and has been perfect ever since.
Old Apr 30, 2012 | 10:26 PM
jrmchevyman's Avatar
Sounds good to me, it will be fine.
Old May 1, 2012 | 01:00 AM
TXSZ66AVLANCHE's Avatar
Have built several ls series engines, just cranked them up on assembly lube and always had instant oil pressure.
Old May 1, 2012 | 06:19 AM
SnakeOiler's Avatar
Of course, disconnect the coils and fuel injectors (or pull fuses). Crank until you get pressure. Don't overheat the starter.
Old May 1, 2012 | 08:05 AM
Mangled03gmc's Avatar
Baltimore Whore
Old Oct 15, 2012 | 05:31 PM
HRV-LS1's Avatar
Finally tried to prelube and check for pressure. Nothing on the dash gauge.
Poured oil over the rockers, filled the filter. Cranked a good 20-25 seconds
more than once, no pressure on the gauge. Should I be worried? I've never worked on engines, or even installed one until now. I've got good grounds.
Need some help.
Thanks.
Old Oct 15, 2012 | 05:37 PM
oakley6575's Avatar
Put a mechanical gauge on the block and crank it. You need to find out if your gauge is actually functioning.
Old Oct 15, 2012 | 05:52 PM
HRV-LS1's Avatar
Funny that you mentioned it. Bought a mech. gauge from Harbor freight. It has a 3/8"-18 NPT adaptor fitting which is too big for the hole at the block. I believe the hole on the block is 3/8" NPT, but which one? If I can get the right adaptor then I can check for pressure. Anybody know what size I need?
Old Oct 15, 2012 | 05:54 PM
oakley6575's Avatar
The oil pressure port is 16mm x 1.5 thread. You can find adaptor fittings that go to 1/8npt
