Engine Mount Part Number
I'm in the process of a 6.0 swap into my 2005 1/2 ton extended cab, and while swapping engines I figure it will be a good idea to replace the engine mounts since the truck has a lot of miles on it.
I've seen lots of talk about replacing engine mounts in the exhaust threads on here, but I've searched a ton and can't seem to find the correct part number.
I've found 4 different part numbers just searching on the internet. Can anyone tell me the differences or which is the correct part number?
So far I've found:
15226251
15226254
15226255
25828247
My truck is 4wd and came with the L33 5.3 engine if that matters.
So far I've found:
15226251
15226254
15226255
25828247
15226251 for use with a 5 speed yellow?
15226254 List L33 Yellow?
15226255 list L33 pink?
25828247 is the latest revision part number of ; 15226252; 15829211; 15829212; 15919101
trxmxzx
Mar 6, 2016 07:55 PM
y2kls1truck
Mar 27, 2005 01:13 AM
