Engine Mount Part Number
Old Aug 4, 2016 | 01:32 PM
jbaum02's Avatar
Default Engine Mount Part Number
I'm in the process of a 6.0 swap into my 2005 1/2 ton extended cab, and while swapping engines I figure it will be a good idea to replace the engine mounts since the truck has a lot of miles on it.
I've seen lots of talk about replacing engine mounts in the exhaust threads on here, but I've searched a ton and can't seem to find the correct part number.
I've found 4 different part numbers just searching on the internet. Can anyone tell me the differences or which is the correct part number?
So far I've found:
15226251
15226254
15226255
25828247
My truck is 4wd and came with the L33 5.3 engine if that matters.
Old Aug 4, 2016 | 08:00 PM
01SilveradoJakee's Avatar
All motor mounts I've done at Gm doesn't matter if it's 2wd 4wd AWD they are all the same. Even from a 4.8 to a 6.2 they are the same. Make sure you use factory mounts. Aftermarket mounts are garbage!
Old Aug 5, 2016 | 06:52 PM
1FastBrick's Avatar
Custm2500's Rude Friend
15226251 for use with a 5 speed yellow?
15226254 List L33 Yellow?
15226255 list L33 pink?
25828247 is the latest revision part number of ; 15226252; 15829211; 15829212; 15919101
Old Aug 14, 2016 | 09:08 AM
jbaum02's Avatar
Thanks for the help.
It seems like they should all work.
I've found the 15226254 for a couple dollars less than the others so I'll pick a set of those up.
trxmxzx
Mar 6, 2016 07:55 PM
Luis3701
Mar 3, 2016 06:54 PM
jbat35
Feb 29, 2016 10:37 AM
y2kls1truck
Mar 27, 2005 01:13 AM
