Engine HELP
Old Jul 2, 2009 | 11:34 AM
nonnieselman's Avatar
or go with the cheapos... NGK TR55s
Old Jul 2, 2009 | 02:49 PM
viciousknid's Avatar
Where's the Beef?
also check the rear o2's
if you go wot are you able to seemingly power through the problem?
Old Jul 2, 2009 | 09:32 PM
streetpunisher's Avatar
Haha sounds like the acdelco iridiums will work. Yes at WOT the problem seems to go away, I will check the back O2s as well, thanks!
Old Jul 2, 2009 | 09:34 PM
Actually WOT off the line is terrible until about 3000 when it picks up and seems to run ok
Old Jul 3, 2009 | 01:51 AM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by AKlowriderZ71
And, ditch the E3 plugs. They are garbage. Looking at your sig, I'd say go back to the stockers. ACDelco iridium.
Yea, those E3 plugs are garbage, I'd ditch those first then go from there...unfortunately I noticed you mentioned Granatelli wires, never heard of anything from Granatelli that ever worked either.
Since it's running OK after 3K, I doubt that it's your cats. From what I've experienced clogged cats will give you symptoms above 3k, usually around 4K and especially at WOT.
A couple of easy things to do are cleaning your MAF and throttle body also, couldn't hurt and it's good maintenance. A scanner or some logging software would definitely aid in your diagnosis if you have access to anything like that...
Old Jul 3, 2009 | 05:58 AM
Where's the Beef?
put a location on your profile. It helps to know where members are located so people can offer in person assistance.
Old Jul 9, 2009 | 11:50 PM
Well I threw some ngk plugs in today and the truck runs like a dream again, thanks for the suggestions everyone much appreciated. E3s are GARBAGE
Old Jul 10, 2009 | 12:29 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Congrats on the repair!!!
superchomper2003
Aug 26, 2015 09:39 AM
nrmskate
Aug 11, 2015 02:44 PM
DrX
Aug 11, 2015 07:25 AM
GMCtrk
38
Aug 9, 2015 08:50 PM
85SS/85GN
Jul 22, 2015 12:48 PM
