engine coolant circuit problem?
Old Dec 7, 2004 | 11:31 AM
mgm5886's Avatar
Default engine coolant circuit problem?
My engine light came on while i was driving and i ran my diagnostics in my programmer and it said something about a malifunction of my ENGINE COOLANT TEMPERATURE CIRCUIT.....and after i started up again it went off....does anybody know or heard about this before?...any help would be great.....
2004 silverado 4.8L
Old Dec 7, 2004 | 06:57 PM
Texas Terminator's Avatar
11 Second Club
um, warranty's are cool or something. probably just a bad sensor. check your coolant level.
Old Dec 7, 2004 | 08:26 PM
chevymec's Avatar
Ive had 2 4.3 do that. The thermostat wasnt working right and it was causing the Check Engine light on.
Old Dec 7, 2004 | 09:35 PM
mgm5886's Avatar
i know...i still have a warranty...but you know i am curious about my truck and would like to know whats wrong with it...
but anyways i think i found out what the problem is...
i read up on it and it isnt the thermostat...its actually the wires or the sensors itself and they could be malifunctioning... and my PCM and ECT read the seperate reading and if the temperature readings vary for more then a degree for more then 2.53 seconds then it throws the engine light on....talk about touchy...
I also heard something about when you change your fuel over it can change the pcm reading....and i did switch back to 87 octane this morning...i usually run on 93 octane....im not too sure about this...but still could just be a coincidence...
Old Dec 7, 2004 | 09:37 PM
chevymec's Avatar
What was the code number?
Old Dec 8, 2004 | 08:36 AM
mgm5886's Avatar
I'm not sure...if i remember right it was P0016 or something like that... ill runt he programmer again today and see if the code is still in the computer
slowlsx
Aug 10, 2015 05:33 PM
hartinclay
Aug 3, 2015 07:03 PM
black00chev
Jul 31, 2015 04:33 PM
ullose272
11
Jul 17, 2015 07:22 AM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
