Engine Conversion, which 5.3 to buy?
Old Feb 3, 2007 | 06:01 PM
cvman's Avatar
Default Engine Conversion, which 5.3 to buy?
I'm doing an engine conversion on my 56 Chevy and I am going to put an iron block 5.3 in it. Is any one year better than another or is there any years to avoid? I may switch to a 6.0 in a few years, using the 5.3 right now frees up a lot of extra money for other things
Old Feb 3, 2007 | 06:07 PM
nightrunner's Avatar
Mr. Obvious
personally id get a 02 version because of the 99-02 cable throttle body being easier to deal with vs. the drive by wire on the 03-06 and the 02 is the only year with cable throttle body that has the new 02-up pcm and slightly larger injectors but if you are going to change the tune and injectors any 99-02 woudl work
ALL 5.3 motors are the same internally from oil pan to intake manifold from 99-06
Old Feb 3, 2007 | 06:08 PM
blake2kz71's Avatar
dont quote me but i believe 99- are the same inside and out.
Old Feb 3, 2007 | 06:09 PM
Mr. Obvious
im 98% sure on that too and i think the only reason the hp is rated higher is in the tune
Old Feb 3, 2007 | 06:11 PM
99Silver6.0's Avatar
99 5.3's had weaker cams too!!!!
Old Feb 3, 2007 | 06:14 PM
blake2kz71's Avatar
never heard that but like said above the tune, and the 05- had efans so that was another 10-15 hp advertised. keep in mind it can be the same motor same year and same tune and run totally different.
Old Feb 3, 2007 | 09:24 PM
cvman's Avatar
How is the cable throttle body easier to deal with? I would think running a wire is easier than trying to route a cable. I have DBW on my new Honda, and it seems like the response is a little slow, is it the same way with the 5.3?
Old Feb 3, 2007 | 09:45 PM
Mr. Obvious
i have heard there is a little delay on the DBW trucks and none on the cable trucks
cable trucks can also run a 90mm Tb without much mods and DBW trucks are having problems from what i hear
Old Feb 3, 2007 | 09:47 PM
Nick™'s Avatar
cable is easier b/c you don't have to go through the expense of getting the tac module and accelerator pedal setup, with a cable you just stick it through the firewall and hook it up...
99-06 long blocks are the same, there was a cam change in either 2000 or 2001, but either style throttle body / intake can be used on any of them
Old Feb 3, 2007 | 10:38 PM
nonnieselman's Avatar
There is only 1 iron block 5.3 right? The LM7.
Whats the aluminum block 5.3? L33??
