View Poll Results: fueling B1-B2 variances
Truck intake NA fueling variance between B1-B2
38.46%
Truck intake FI fueling variance between B1-B2
15.38%
Ls6/ls1 intake NA fueling variance
0%
Ls6/ls1 intake FI fueling variance
0%
Aftermarket intake fueling variance
23.08%
Im an asshole and I dont give a shit about variances
23.08%
Voters: 13. You may not vote on this poll
Electric fan satisfaction poll
Old Apr 17, 2004 | 07:42 PM
BigTex's Avatar
Default Electric fan satisfaction poll
For you guys with electric fans, how would you rate their cooling quality?
Old Apr 17, 2004 | 07:48 PM
GREGGO's Avatar
Towed my travel trailer with my LT1's and never had an issue. 6300#'s in Texas hill country.
BlownChevy's Avatar
blownerator
25 Year Member
Could not be happier with the fans! Best mod for the money.
Old Apr 17, 2004 | 07:51 PM
XLR8NSS's Avatar
Adkoonerstrator
Flexalite 282's, 6.0L radiator, 160 degree thermo.
No problems keeping things cool while sitting still in traffic on 100 degree days with the A/C on.
One little gripe about the controller clicking on/off when it reaches the turn off point but, other than that no problems so far.
Engine bay room is gonna be worth it here soon also.
Old Apr 17, 2004 | 08:52 PM
BigTex's Avatar
OK, I see where this is going. My vote is currently the only one for
"poor" cooling.
I have a cooling issue and needed to know whether it is due to poor cooling qualities of elec fans or something else. I haven't looked into the issue yet, but will tomorrow.
I stopped by a track on the way home last night after putting 100 highway miles on the truck. Temps were in the mid 70s. Even with spending 30 minutes coling down in the staging lanes, my engine temps were 208, but even worse, my IATs were in the 150 range. Second run was basically the same way.
Needless to say, I ran like crap. Only ran NA, in full street trim, full exhaust, 20s, tailgate up, and an extra 100 pounds of computer equipment in the cab. 14.3 and 14.2 - The extra heat caused me to run alot richer and have lower timing than normal. My O2 readings were in the .94-.95 range.
Old Apr 17, 2004 | 10:36 PM
PCMFORLESS's Avatar
Tex,
I have seen a similar thing. Since we did not find a 160 stat for my 04 we cut out the center and when cruising the truck mainatins 170's, but in traffic, or just sitting it will work it's way to the 190's to low 200's. I've got the LS1 fans. Maybe we should try some water wetter and see what we can do. The stock setup may not have the capacity to keep us in the 170's to 180's no matter how big a fan we run.
Bryan
Old Apr 17, 2004 | 10:54 PM
BigTex's Avatar
I understand that it would get into the 190-200s. Thats no big deal. My issue is that with 80* outside temps, I get up to 220+ in traffic. WHen the Texas 100* outside temps hit, I'll be doomed.
FWIW- I have a cold tstat, more water/less Dexcool, and water wetter in the system right now. The flex 282 fans are larger than LS1/LT1 fans, so I shouldn't have this issue. I'm sure there is something else I've got messed up.
Old Apr 17, 2004 | 10:57 PM
XLR8NSS's Avatar
Adkoonerstrator
Are you sure BOTH fans are running and that they're running at full speed when the temps get up there?
Old Apr 17, 2004 | 11:10 PM
FILE's Avatar
I love mine. I have have not had any problem yet. I hope I don't when the 100+ daily weather gets here.
Old Apr 17, 2004 | 11:34 PM
mwalls54's Avatar
Need More N2O Mod
i havn't had a problem untill two days ago.
well the past two days i have been in pegion fordge, TN to spring rod runs a car show/ curise. i rode around for about 5 hours friday nite in 5 mph traffic and my fans ran non stop. the temp out side was 65* at the most and got cooler as the nite went threw. temp of truck was 210-220 range. and i have 160 stat. well today i did the same thing as last nite and the temps were in the 90s. i stoped and got gas and battery was dead. i had some one jump me off and it started. i rode it around pretty hard for about 30 min to let the alt charge up the batt. well it didn't work. i had to get boosted again. i drove 2 hours home and the temp stayed 210 running 80 mph. and as of right now the battery is still dead. i ordered a optmia red top and i will replace it tomorrow.
